spline curves drawn in 3d space: having trouble using "handles"?
maker9876
maker9876
As in the screencast:
http://autode.sk/2jybcGq
Have 3 rectangular sketches on parallel planes.
Connect 3 of the corners (with a view to using them for Rails in a Loft).
(This is an operation in 3D space because sketching on a plane that does not intersect any of the 3 points).
Try to manipulate the handles to adjust the angle of the spline.
Unable to.
Should this be possible?
HughesTooling
You have to use the move command when working in 3d.
Mark
Mark Hughes
Owner, Hughes Tooling
maker9876
Makes sense.
Even better, it turns out Move works not just on the spline curve itself but also on the spline point "handles" giving quite some flexibility!
