Spline centering issues
In brief: What is the best way to make a spline *auto-center* between two other splines? I have been working on a drawing for a curved component that requires a wire to run through its center. The outer lines and the inner line are Fit Splines. I would like the center line to auto-center as I adjust the outer splines, matching their curvature.
I have parameters for Height and Width, and some constraints, such that changing the parameter allows the splines to auto adjust. The issue comes in once the center spline for the wire gets added with Midpoint constraints, while it works at first, once the Height and width parameters are edited the center line doesn’t auto center correctly. how can I fix this so that I don't need to manually correct it each time? Is there a way, for example, to make the tangent and curvature handles of the center spline always be the average of the outer splines? Any help will be much appreciated!
Oswaldo
Link to sketch
https://a360.co/37TyTzj
LeonardoBN
Hi @Anonymous.
We had some discussion here about something similar:
Is it possible to sketch an intermediate curve like this?
Leonardo Brunelli do Nascimento
Chemical Engineer
