Specific mass of a component
mac_ito
mac_ito
hello, it would be relevant to be able to manually apply a specific mass to a component rather than adding the different materials that compose it.
In the case, like me, where you work with a lot of imported elements, it is really time-consuming to display the weight value of these elements
shekar_sub
Hi
we have Manual and automatic point mass in simulation. With Manual point mass you specify the location of the mass. With automatic point mass you can select bodies and components and those will be replaced by a mass value. Do you need something similar in the Design workspace? Thanks
mac_ito
hi, yes the goal is to be able to show the center of mass in the design workspace. To date it is necessary to apply each material of each component which constitutes the design, it is totally absurd in the case where a component from a subcontractor is imported. The second objective is also to be able to display the mass value of the components in the tables of the drawing space and then to be able to export them in .xls or .csv
Capture d’écran 2022-09-22 à 13.19.54.pngCapture d’écran 2022-09-22 à 13.24.15.png
