Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Solidworks part upload to Fusion 360 free edition
leclere.patrick
Observer Observer
leclere.patrick
Observer
Observer
Since the last update the translation of Solidworks .SLDPRT files  to Fusion360 format doesn't work for me  since the last update. It worked on previous versions. I attached a file .
Is there a way to fix that because I use quite often some Solidworks files send by a friend
HughesTooling
Cloud translators are no longer included with the free version. You could try using grabcad to translate.
Mark
Mark Hughes
Owner, Hughes Tooling
TheCADWhisperer
@leclere.patrick wrote:
... some Solidworks files send by a friend
Tell your friend that flat bottom holes are more expensive to manufacture than drilled holes (118°), and that threaded holes can be generated directly using the SolidWorks Hole command (the three holes were specified to be M5 threads).
See attached file.
leclere.patrick
Observer
Observer
Thank's for answers.
That's what I feared.
