Not at the moment.
There is a tool that converts solid faces to T-Splines but it results in creating Patch faces that must be edited in the Patch workspace to add them to your solid model again.
Look for Sculpt > Modify > Convert.
TOwens777,
Can you provide me with some more information about the workflow that you are trying to accomplish. Any models or screen shots will also help. To go from Solid to T-Spline you can use the covert tool. When you are in the sculpt workspace there is a convert command under modify. Inside the convert tool box use the brep "BR" option to select solids.
Cheers,
Mike Prom
Thanks for the response. I was hoping to do my initial model in solid form and then convert to t-splines to edit some of the more organic shapes.
I was able to convert using the Covert tool but that wasn't very useful. Editing he patches created would be more work than it is worth.
Thanks anyway.
