Solid to T-Spine?
Solid to T-Spine?
TOwens777
Solid to T-Spine?
TOwens777
Is it possible to convert a solid object to a t-spline?
Thanks!
Phil.E
Not at the moment.
There is a tool that converts solid faces to T-Splines but it results in creating Patch faces that must be edited in the Patch workspace to add them to your solid model again.
Look for Sculpt > Modify > Convert.
Phil Eichmiller
Software Engineer
Quality Assurance
promm
TOwens777,
Can you provide me with some more information about the workflow that you are trying to accomplish.  Any models or screen shots will also help.  To go from Solid to T-Spline you can use the covert tool.  When you are in the sculpt workspace there is a convert command under modify.  Inside the convert tool box use the brep "BR" option to select solids.
Cheers,
Mike Prom
TOwens777
Thanks for the response.  I was hoping to do my initial model in solid form and then convert to t-splines to edit some of the more organic shapes.
I was able to convert using the Covert tool but that wasn't very useful.  Editing he patches created would be more work than it is worth.
Thanks anyway.
