Solid body showing in edit form mode
Hi Everyone,
i prepared some body with t-splains and translate it to solid body.
Now when i choose "Edit form" i see my t-splain form, but solid body is also visible overlaping t-splains. So i cant see what i am doing while making t-splains smaller than solid body.
Also after hiding FORM in edit form mode, solid body is visible.
Any help friends?
jeff_strater
This looks like a bug to me.  I'll investigate.  What is supposed to happen is the BRep body is shown, but "ghosted" (rendered transparently) so you can see what you are doing.  This seems to be broken.  In the meantime, you can shut this off entirely by unchecking this preference setting:
I'll follow up when I see whether this is a bug.
Jeff
Jeff Strater
Engineering Director
jeff_strater
Yes, this is definitely a regression.  We will get right on a fix.
Jeff
Jeff Strater
Phil.E
The workaround for this is to turn off the visibility of the solid model body, or change it to lower opacity, prior to editing the Sculpt body.
Steps:
While in model mode, right click on the body node in the browser and pick "opacity control" or just click the bulb next to it to shut visibility entirely. Then edit your sculpt.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
