solid bodies from component
I downloaded a .obj file and want to 2D print. I get this error message
"The desing contains no solid bodies. A drawing cannot be created"
How do I create solid bodies from components. What I loaded has only components.
HughesTooling
I suspect your obj file is a mesh not NURBS surfaces and I'm not sure you can make a 2d drawing from a mesh. Can you get the part in a different format, something like STP of IGS that should be surface models.
Mark.
Mark Hughes
Owner, Hughes Tooling
