Snapping to Mesh Object points while sketching
Is there a way to snap to points on a Mesh Object in the background while in sketch mode ? It IS possible with a Body Object , but I can't get it to work with a Mesh Object.
jodom4
Hey chalbers,
Meshes don't behave the same way as solid bodies. The best way to get usable mesh geometry is to use Fit Curves to Mesh Section under Create in the Sketch environment. The UI is a bit different now, but it still works as described in this youtube video.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
