Snapping a TSplines object to center of world
Just as the title says anyone have ideas how to move an object to the 0 of one axis? Struggling to find a simple solution for this basic function.
-John
PhilProcarioJr
@Anonymous
CAN you show us a screencap of your T-Spline model in the workspace?
Phil Procario Jr.
Owner, Laser & CNC Creations
@PhilProcarioJr From the screenshot you can see all the numerical values are set to XYZ of the box it started as.
Many programs allow you to swap between the box coordinates and the world coordinates, just wonder if this functionality is built into fusion.  Obviously it would be best to just build the form from the start at the origin every time but sometimes that's not always possible...
PhilProcarioJr
@Anonymous
If I understand you correctly you want to use the move command and not the edit command. Not exactly what your after but should work.
Phil Procario Jr.
@PhilProcarioJr aha nice, that'll work just fine. Thank you, and you have a good Friday!
PhilProcarioJr
@Anonymous
Glad it helped, have a good weekend.
Cheers
Phil Procario Jr.
