Snap to a point for Construction Axis perpendicular at point
I don't know what I'm doing wrong, but I is seems like it should be a very simple task to be able to make an axis perpendicular to a plane that at a specific point. The problem I'm having is that select instance won't let me snap to a point that I created in a sketch. I also tried creating a construction point at the sketch point an I can't snap to that either. What am I doing wrong?
Never mind I found the correct command.
Pavel_Holecek
Hello Simon,
there are two similar commands how to create a work axis.
1. Axis Perpendicular at Point  -  new axis is placed to a point where you click with mouse
2. Axis Perpendicular to Face at Point - select a point and then a perpendicular face
Let me know if you need more info
Regards
Pavel Holecek
Autodesk QA team
Pavel_Holecek
I added an screen capture for those two commands:
Pavel Holecek
Autodesk QA team
Scoox
Can you give an example of when you would use such a pointless tool?
