- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Folks,
I keep finding areas in F360 where a task that is absolutely trivial in Swerks or Pro-E is simply unfathomable in F360. I’m frustrated that I can’t puzzle through the magic sequence of work-arounds to be able to make simple geometry that captures design intent and/or to make simple assemblies that give me flexibility to experiment with my designs.
While it is encouraging to see many new features being pushed to F360, it is very disheartening to see that so many of the core usability issues around easily creating and assembling good geometry are still not addressed after so many release cycles. It makes me worry that 2 years from now new users will face the same hurdles of a very unintuitive toolset. Of course there have been software packages that have managed to flourished with such shortcomings (SAP comes to mind) but this is generally the exception not the rule . . .
Regardless, the issue at hand today is as follows; I’ve got a fairly simple body that I’ve imported into F360 from another CAD package. I reoriented the geometry to line up with the default origin planes in the file. Now I am trying to add a rectangular thru-hole feature into the existing geometry. I want to line the center of the rectangle (using center-rectangle sketch tool) with one of the planes of my origin normal to my sketch plane and finding that while the center of the rectangle origin “snaps” to line up with the normal plane, it is not in fact anchored there. Adding dimensions to the rectangle demonstrates that fact as the edges of the rectangle remain blue when it is not fully constrained relative to the origin plane. I’ve included a screenshot to demonstrate.
I’m hoping there is a simple constraint option I am missing in the sketch palette, but any attempts to use any of the constraints on the palette merely anchored the entire rectangle in place - not what I wanted it to do - I’d like to lock it to the origin plane that is normal to the sketch plane and just dimension off the upper edge of my geometry to set the position of the rectangle relative to the edge. Is there an easy way to do this - preferable without resorting to projecting geometry? Projecting is one of those areas where I think F360 is pretty weak when lined up against the competition.
Also, prior to submitting to IdeaStation, are there plans to move the dimension tool onto the Sketch palette? I can’t fathom why it isn’t there already as you always need it, and now it is several clicks away unless you anchor it to the main top tool palette.
Art
