Smoothen/Simplify solid
haraldZXTDW
haraldZXTDW
I have a solid which is the result of a body rotated around an arbitrary axis (the solid consists of 40 merged bodies):
I want to smoothen the solid's surface, to get rid of the steps between the bodies. What is the best way to achieve this?
jeff_strater
Have you tried Solid Sweep?  This option to Sweep allows you to sweep a solid body along a path, and does the "smoothing" for you.  Create a circular path, instead of an axis to Revolve around, and use Sweep, selecting "Solid Sweep" as the option.
Jeff Strater
Engineering Director
haraldZXTDW
Is there a way to control the angle around the rotation axis? For the rotation method in the first post I used  +/-20°.
haraldZXTDW
Attached is a f3d file which shows how the solid is created.
jeff_strater
The easiest way to control the sweep is using the path.  Just make a circular arc that goes 20degrees in each direction. You may have to do two solid sweeps - I'm not sure just now whether solid sweep supports two directions in one sweep.
Unfortunately, I don't have time right now to play with your model, but it should be relatively straightforward.
Jeff Strater
TrippyLighting
What you attached isn't a single solid.
Attached is a version with a solid sweep, that took some workaround past a solid sweep fail.
haraldZXTDW
Thanks a lot for the example.
