Thanks for the invite, @Zephyr958,
I think there is more going on here than I first suspected. At first, I was convinced that the problem was the large number of symmetry constraints from the mirrored geometry. Sketch Mirror, when used with large numbers of geometry, is a performance hog.
Usually, I recommend that people should not do this scale of mirroring in a sketch - you are much better off if you build 1/2 the sketch, and do the mirroring in the solid world, instead.
So, I went through and removed all of the symmetry constraints. Even, then, the performance is horrible. This is a complex sketch, but it should be well within Fusion's capability.
However, I went through and deleted all the symmetry constraints, and the performance, while better, is still bad. We will need to dig into this further. Thanks for sharing the model
Jeff
Jeff Strater
Engineering Director
