Sliding joint with offset components
Hi all,
I'm trying to get to parts to move against each other, when the left pin is pushed down the other pin must move when it's aligned with the recess. Both mean to be spring loaded, the left one from below to top and the right one from right to left
So I need those faces to touch each other.
Can you help me?
CoertHFT
g-andresen
This should be possible with the "Rest" option (slider menu).
Slider > Rest
günther
