Move/Copy command
Move/Copy command
r_goulter
Move/Copy command
r_goulter
What happened to the Create Copy check box in the Move/Copy dialog?
r_goulter
Clarification! Create Copy check box is only missing when Move Object is Faces.
jeff_strater
Correct.  There is no way in Fusion to make copies of selected faces, so this is also blocked in the Move command.
Jeff Strater
Engineering Director
TrippyLighting
Well ... the accepted and often practiced technique is to make a 0mm offset. That has the same effect as copying the face.
r_goulter
Thanks Peter for the tip. Is there some trick to making a 0mm face offset. The Offset Face command is not accepting 0mm for me. Ross
TrippyLighting
I was referring to this command:
r_goulter
Thanks Peter.  Ross
