Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Slider problem
2 REPLIES 2
gordonclamp
281 Views, 2 Replies
Slider problem
gordonclamp
Hi, The problem I mentioned earlier on slider feed back has now shown up on existing models that had worked preveously with no problem. Added to that a model I have been working on all morning has dissapeared completely. Is there a problem at source?
Slider problem
2 REPLIES 2
HughesTooling
in reply to: gordonclamp
HughesTooling
Have you tried closing and restarting Fusion. If that doesn't help try a reboot of your computer as well.
Mark
Mark Hughes
Owner, Hughes Tooling
Mark
Mark Hughes
gordonclamp
in reply to: HughesTooling
gordonclamp
Hi Mark
Tried that several times. If I click the “drive joints” button and then the slider triangle the large direction arrow appears along with the distance readout. This I used to be able to get by double clicking the slider arrow. Even the revolute flag takes several attempts before the circular arrow and readout window appears.
If I attempt to double click the slider arrow all it does is to highlight the component I am hovering over, if this happens to be the component I wish to slide then it allows this but without any control. Regards Gordon
Hi Mark
