Hi all,
First post, I am looking to create a slider joint for a bracket and a guide rail, but when I create the joint, it only moves along a single axis, and doesn't continue onto the curved part of the guide rail, which a basic L-shaped rail with a radius.
Is this even possible within Fusion ?
Sorry, still a beginner here...
Thanks in advance.
Solved by chrisplyler. Go to Solution.
Not possible in Fusion.
The set of possible Joints is known to be insufficient to cover all real world possibilities.
Thanks @chrisplyler , I appreciate the feedback.
Any other Autodesk software that might be able to do this ?
