slider axis does not match origin axis fusion
brad9126
brad9126
While I'm creating a slider joint, in the Motion tab of the Edit Joint dialogue, you can pick which axis you want Component 1 to move along. Why does this not always agree with the Axis in the design space? In other words, if I want Component 1 to move along the X axis in my design window/space, I often have to pick Y or Z in the Motion tab to get it to move in the correct manner.
Am I doing something wrong?
Is this just a quirk of Fusion?
Have I picked the "wrong" snap point for Component 1 or 2?
I always get the sliders to work but I would like to have a better understanding of this feature
Thanks in advance,
Brad
jeff_strater
joint axes are determined by the geometry selected, and generally have nothing to do with the global or component origins.  A joint is composed of two joint origins.  You can see a preview of these when constructing a new joint:
The joint origins are always positioned so that the Z axis points away from the geometry selected.  Hint:  coordinate systems in Fusion are always displayed as:
  • red: X axis
  • green: Y axis
  • blue: Z axis
as you can see in the image, the Z axes of each component are oriented away from the selected geometry.
When a joint such as a slider is created, the default is to use the Z axis as the slider axis.  This can be at any angle, depending on the joint origin.  As you can see in the video below, you can have a slider axis that is at any arbitrary angle with respect to the global or component origins.  Hope this makes things clearer.
Jeff Strater
Engineering Director
brad9126
This helped greatly. Thank you!
