Sketching lines since the update
since the last update sketching a straight line has became a little more frustrating.
so far i have noticed that when i sketch a line, it will make a really small (almost noticeable) line at the start that i didn't intend to make, and when i make angles it will turn it into a radius without looping the courser like in auto cad.  sometimes the radius inst noticeable until you zoom in.
can the sensitivity be adjusted for this?
HughesTooling
Personally not see any difference with today's version. I have seen the problem you're talking about and it's down to a click and drag. Click and drag as the first pick with the line tool will give you the short line and click and drag after the first point will give you an arc. I have to use a thumb ball mouse and suffer with slight moves at time when I click, the problems I see are the short lines\arc and also the dimension tool will cancel. I've reported the problem a few times but there is no setting to help with this. If you're suddenly seeing a problem you might want to try another mouse or new batteries just in case it's just a coincidence there was an update.
Mark
Mark Hughes
Owner, Hughes Tooling
that might be the bingo there. it might be a result of phantom mouse clicks that just happend to start at the update.    it seems unusual though as they all are really small and usually by the nodes.  i will have to investigate that further.
etfrench
@HughesTooling nailed it.  It's been frustrating me for a long time as well Smiley Mad
Creating a line requires you to verify it's only a single line every time you create a new line.
@jeff_strater  What's the status on this bug?
ETFrench
