Sketching in my prefer view
jeruedas
jeruedas
Is there a way to keep Fusion from moving my view when sketching in a plane? This is what I mean. With the home view, I select a plane to sketch into. Then select the sketch tool, and the view changes to the top view. Very annoying because every time I have to go and change the view back, so I can sketch with the references I need to use. Is something I am doing wrong when sketching? Is there a way to make a view as default? Thanks for the help.
jhackney1972
Maybe taking this Preference setting check mark off will help.
John Hackney, Retired
Josef_A_K_
Great, I have also missed this possibility, Thank You.
jeruedas
Thanks It works. Never imagine this will do it. Back to work now with less frustrations.
