Sketching a line an controlling it's angle
engineer1984
engineer1984
Simple idea here... I drew a random box, with angles as shown.  Now I'm going thru the phase of constraining it.  I have Googled and I cannot find a way to simply define the angle of the line...
Can someone help me?  This has to be simple, right?
g-andresen
Create angular dimensioning in the active sketch between your line and the horizontal or vertical (purple) line.
If necessary such a line must still be created.
günther
engineer1984
So I can't just draw a dimension for an angle between two lines like any normal software?  I have to re-draw the line?
g-andresen
the hint results from the fact that the conditions in the screenshot cannot be seen beyond doubt.
Next to blue lines there are others, e.g. purple ones, which indicate projection.
Please share the file for a better view.
günther
jeff_strater
yes, you can create an angle dimension.  Use the dimension tool, pick the two lines you want to define an angle between, and place the dimension.  Have you tried the dimension tool?
Jeff Strater
Engineering Director
engineer1984
Thanks, that didn't seem intuitive to me...
