i'm working on a project wher i'm iporting a DXF or SVG and then redraw the parts i need on a separate sketch.
so i import the DXF/SVG which creates a sketch for this.
i then create a new sketch on the same plane (world XY) and in this new sketch i draw lines by snapping to the parts from the imported sketch so i have a clean Fusion sketch to start modeling my features (it's a fretboard for a guitar and in the imported skecth the lines for the frets are too long so i redraw them in the new sketch to the correct length intersections). But on the first line it creates some purple dots/lines unrelated to the line i drew which seem to be projections of curves from the imported sketch.
here is a closeup of the first line with the dot and the unrelated generated lines:
and here are the other lines which draw fine without any pink/purple projected thingies:
what the heck is going on here ??? ![]()
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
