SKETCHES | what do the pink/purple dots/lines mean and why are they generated ?
rumpelstielz
Message 1 of 14
rumpelstielz
i'm working on a project wher i'm iporting a DXF or SVG and then redraw the parts i need on a separate sketch.
so i import the DXF/SVG which creates a sketch for this.
i then create a new sketch on the same plane (world XY) and in this new sketch i draw lines by snapping to the parts from the imported sketch so i have a clean Fusion sketch to start modeling my features (it's a fretboard for a guitar and in the imported skecth the lines for the frets are too long so i redraw them in the new sketch to the correct length intersections). But on the first line it creates some purple dots/lines unrelated to the line i drew which seem to be projections of curves from the imported sketch.
Screen Shot 2016-08-12 at 21.48.29.pngScreen Shot 2016-08-12 at 21.49.43.png
here is a closeup of the first line with the dot and the unrelated generated lines:
and here are the other lines which draw fine without any pink/purple projected thingies:
what the heck is going on here ??? Smiley Surprised
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Replies (13)
Message 2 of 14
HughesTooling
Check in preferences and make sure Auto Project is off.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 14
rumpelstielz
hey, once again you're the man Mark 🙂
thx so much for the quick help, this was freaking me out and i didn't know where to search !
Message 4 of 14
rumpelstielz
ah, bugger ... the problem when switching off this option is that the cursor doesn't snap to the other sketch anymore. so none of the two options solves the problem. so in the end it was much faster to clean/edit the curves in Rhino, export a DXF and then import them back into Fusion ...
Message 5 of 14
HughesTooling
If the 2 sketches are on the same plane it should work. If they're on different planes what I normally do is use the project tool and just project the end points I need, might not be practical with the amount of curves you're working with though. I don't like auto project feature as you can end up with lots of double lines\curves I'd rather project just the points\curves I need.
Mark
Mark Hughes
Message 6 of 14
What do the purple lines dots actually mean ? In my case turning that off had no effect. I see purple lines and dots in many area's with no clear explanation of what the issue is.
Message 7 of 14
pmcnicoll
I'm experiencing the same issue and am hoping to refresh this thread with a comment.
Message 8 of 14
mavigogun
Study up on "Project"- the ability to imprint  the shape of bodies and other sketch geometry on a Sketch.   It's super useful.   Say you need to know how the end of a shaft WAY over on the other side of a design relates to stuff you're sketching on this side-- just select the related edges of Sketch elements or bodies and press "P" for project.   If you need the cross section of a form, use "Project Intersect".   Need to capture a 3D shape?   Say, the seam between two parts?  Include 3D geometry is the tool.   More basic, Project can be used to transfer Sketch elements from one Sketch to another.    All of these Projected elements are drawn in purplish color, depending on your workspace Environment settings.
The Solution marked above points to a setting that may result in the incidental inclusion of Projected elements.    If it looks like someone has been drawing parts of your Sketch in Burgundy wine, some projection's been going on.   Hope that helps.
Message 9 of 14
pmcnicoll
Thank you for the information, but this doesn't address the issue I (and I think he) had. I'm familiar with the project tool, and it's wonderful. However, after de-selecting the setting in question, I'm still getting burgundy lines being projected into sketches, sometimes massive ones unrelated to the current sketch.
Message 10 of 14
HughesTooling
Have you unchecked both auto project options in preferences? My post above is quite old and another opton, Auto Project Edges on Reference has been added.
Failing that can you download screencast and record what you're seeing.
Mark
Mark Hughes
Message 11 of 14
pmcnicoll
Yes, I have both unchecked. I actually just downloaded Screencast but windows is now saying that the software is not designed to run on windows, so I have a new issue to solve.
Message 12 of 14
JamieGilchrist
Hi  rumpelstielz,
and to your question about what do the colors mean,  this should help.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 13 of 14
pmcnicoll
That helps my transition from Solidworks tremendously, thank you.
Message 14 of 14
HughesTooling
@pmcnicoll Are you working so you're looking straight at the plane you're drawing on. Try this simple test, draw a cube and start a sketch on a face. With the view straight on using Look At you should not get any references or projections, rotate the view a bit and you'll be able to pick end and midpoints but the edges used will be autoprojected.
Mark
Mark Hughes
