Sketch Visibility
Sketch Visibility
Sketch Visibility
Is there a way to cut an existing model back to the sketch plane in Fusion (like using the F7 key in Autodesk Inventor sketch mode)?
Thanks in advance
Mark
jeff_strater
The "Slice" checkbox in the sketch palette will do this:
Jeff Strater
Engineering Director
Many thanks for the help - I suppose I'm asking too much to be able to Project Cut Edges like Inventor also?
Mark
jeff_strater
you mean like this?  Use the Project -> Intersect command, with the selection filter set to Body.
Jeff Strater
Awesome - Many thanks Jeff!
Guess I just need to find where things are in Fusion...
Mark
