Sketch protractor divisions
martin.oldershaw
martin.oldershaw
I am designing a simple gauge to measure aileron deflections on model aircraft. I will be 3d printing the design and wish it to include printed divisions showing the degrees of a protractor.
I want to sketch it on a face, give dimensions to the pattern of divisions so I can extrude. I haven't been able to work this one out yet.
Some advice please?
davebYYPCU
Sketch one line, 0 - 0,
then cut the face using that line with a Solid Pipe as a cutter,
Circular pattern it, (the Pipe cut feature), I went 45 degrees at 5 degrees, then mirror for the other side,
Sizes to fit the wing etc up to you,
might help....
martin.oldershaw
Exactly what I needed.
Many thanks
