Message 1 of 14
sketch problems
Good day,
having come from a turbocad environment, i find the fusion sketch environment very rigid and hard to use. i am new to the software, so probably too soon to complain about it.
major issues:
- You cannot define object handles. so i draw a square that has a handle in the center of the square. i can then dislodge the handle and move it to a midpoint or endpoint and then use my new handle to grip the part and snap it to an endpoint, center, midpoint, entity, etc. with fusion you have to use dimensions to relate the drawings. it feels clunky and slow right now. the move tool is also a bit clumsy. i am new to it so i will try and see what else is possible.
- Some lines, once placed cannot be accessed again. I do an offset and after that i cannot snap a line to it. no matter what i cannot touch it or move it. it is locked. i cannot delete the offset constraint either it is locked. i cannot convert it to construction lines. nothing. i am still working in the same component, in the same sketch...
- some strange things are not allowed. offset will not allow an offset of an offset. just blocks it. i can understand a complex shape, but a straight line?
- even components that have been turned off get in the way of shapes i want to extrude and then it is really complicated to get to the shape i want to select to extrude.
- the project tool is very strange i cannot select an entire chain. have to select each link on its own. and if you make the mistake of accidental clicking the object instead of an edge it will immediately extrude the entire thing and it cannot be undone. have to delete the sketch.
as i say i am new to fusion and i am enjoying it enough that i will keep learning, but i don't understand some of the methods used to work.
if anyone has some ideas as to how to work these things let me know.
thanks
