Convert a surface in meshes then flatten the meshes (flat pattern) ?
CapGuy
CapGuy
I wonder how to convert for instance a surface of a solid like a quarter of a sphere in meshes (say : how to triangulate this surface),
then flatten this mesh stuff onto a plan ?
Thank you very much if you are able to tell me how to do this !
Cordially,
Guy
May The Force be...yond !
laughingcreek
If your a cheapskate like me, A Meshmixer to Pepakura workflow works well.  I'm sure there are other programs out there that will do the trick also.
TrippyLighting
I'd ask what you want to do with such a flattened surface ?
Depending on the  answer there are other methods.
You could use the Exactflat plugins for Fusion 360as well. But i've head its a intel pricey.
CapGuy
Hi Peter,
I could tell you what I'll do, but in this case I'll have to kill you after this 😉
Seriously, I knew ExactFlat and the price is not the only problem for me : it can stretch the fabric used, and I don't want that.
What I want is exactly what I described. The goal is to create something like a kitesurf wing (take a look at my profil image) then to flatten it to send DXF files for laser cutting the fabric needed to sewing the real thing in the real life.
I am able to do this within Rhino3D and it works fine, but I would prefer to understand how to do it within F360 and to be confident with this procedure.
Thanks a lot for your time,
Cordially,
Guy
CapGuy
After some search about "tessellation" I guess the "BRep to Mesh" F360 function will help me for the first part of this action.
But after the meshing procedure, I will need to choose the joints to cut, then to unfold (to flatten) the meshes and put them on a chosen plan.
How to do this cutting and unfolding on a plan ?
Thank you very much for your help,
Guy
CapGuy
[empty message because erasing is not possible]
