Sketch pattern along a path
I'm trying to create a pattern in the sketch editor that follows a curve. I've attached a picture for reference. The perforations/holes are currently created using the rectangular pattern tool using a single circle which is easy to extend in the horizontal or vertical direction along a straight path. However I need this perforation pattern to follow the curved line on the left hand side of the image. Any ideas on how I can do this?
davebYYPCU
Pattern along a Path, exists for solids,
create the plate and a row of holes at the start of the curve,
Use Create > Pattern > Pattern on Path,
Using sketch patterns slows your computer down, Fusion prefers patterns with solids.
Might help...
