Sketch orientation
Sketch orientation
steveVLDE4
Sketch orientation
steveVLDE4
This is a dumb question I'm afraid...but I find it much easier to sketch objects when they are vertical or horizontal due to the snap fits....is there a way to rotate the sketch plane so if I want to sketch something at a 20 deg angle, I can rotate the sketch plane 20 deg so it brings it into the vertical/horizontal axis?
For example if your object is at 20 deg, and you want to draw a rectangle - the rectangle cannot be at 20 degrees...
davebYYPCU
Use
Construction > Plane at Angle.
Create Sketch on that plane,
Look at that sketch, will be same as all other sketches.
Might help...
steveVLDE4
thanks
