Sketch not fully constrained
- Mute
- Permalink
- Report
I have a very simple sketch - a circle vertically centred on existing geometry with a fixed distance from another piece of geometry on the left. The vertical centre is accomplished with two vertically constrained construction lines which have an equal length constraint. From what I can see there should be no way for the circle to move, however the sketch is not fully constrained:
If I replace the two vertical construction lines with a single horizontally constrained construction line with a midpoint constraint the problem goes away:
Can someone help me understand why the first sketch is not fully constrained?
Thanks!
