- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
This is a continuation of why Fusion 360 is not really ready to be adopted for art work, such as one might cut with a 2D cutter such as plasma, laser or water jet. Episode 1 is far more critical but seems to have stalled in the Autodesk community without any solution. These are serious problems that can be encountered by anyone using the Sketch mode.
This episode is about pasting a simple sketch content to another sketch in the same design. This should be one of the simplest things to do but it has a flaw (besides the horrendous Episode 1 ERROR). It is:
1) When the copied sketch content is pasted, it is rotated 180 degrees.
Why is this a problem?
1) The reference to the location in the grid from the first sketch is lost when you rotate it. Now you have an issue with re-indexing it to the original sketch if you need to do so.
2) One you use the manipulator to rotate it back to its correct vertical orientation, there is some kind of orientation recorded in the data. Then when you export as a DXF file, which you are certainly going to do because Fusion CAM is not anywhere near ready to encode a file to a controller efficiently that has the ability to control a torch height system or control height and feed rates and accelerations for small problem areas. you are gong to find that it is rotated in that CAM system. Is that an issue with the CAM system, in that it doesn't utilize the orientation that Fusion is clearly recording in the file? Yes, and that may be corrected, but since all we wanted in the first place was a copy in the same orientation on the screen. it should not be that way in the first place.
(Note: Fusion CAM is solid oriented. Great for Milling, I love it. For 2D, its impractical for more reasons than this post deserves)
So, through this episode 2, the current status of the Sketch mode is that when you copy from a sketch to another sketch, you will likely lose arc lines or have them deposited somewhere randomly with a mess of unmovable points and the paste will likely, but not always, be rotated 180, so that it appears upside down.
Sample Design: http://a360.co/2ih4ShG
Jeff
解決済! 解決策の投稿を見る。
