Sketch Menu Problem
Sketch Menu Problem
TUKTAK3D
Message 1 of 14
Sketch Menu Problem
TUKTAK3D
Hello
I am newby for Fusion360 and I am sorry for my English.
I just tried to start tutorial from the first step which is start drawing the profile line lol
But mouse really getting slow from second point of line and
I couldn't handling the mouse pointer cause of slow and slow with each point step of line
Also after close the line(just 4~5segment) and then mouse pointer slow about 5~10 second
I tried most of all suggestion for fix this problem but I can not fixed.
This is my system
 LG ultrawide wqhd monitor and 3440 x 1440
Intel 5820K CPU
32g memory
GTX1080 4G
I think this system is good enough for learning
Other all  3D CAD CAM programs are working well...even include big data
But why Fusion360 can not be drawing just 1 single spline object lol
All sketch menu have same problem..Mouse getting slow.
Create menu is look okay.Making 3d object look fine and pretty fast.....I just can't make profile curve
Help me please,
Replies (13)
Message 2 of 14
Beyondforce
Hi @TUKTAK3D,
Will you please go to the Help menu (?), click on Graphics Diagnostic, take a screenshot of that window and send it to us.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 14
TUKTAK3D
Thanks for reply and I will check your newbies channel.
I attached my graphic diagnostic screen shot
Thanks 😄
Message 4 of 14
Beyondforce
I think it might have something to do with your high resolution.
This should help: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Per...
If it doesn't, please let me know.
Ben.
Ben Korez
| YouTube
Message 5 of 14
TUKTAK3D
Yes I already tried that way but not working
It still slow and same situation
I attached my monitor model just in case
This monitor has not normal size so I just wondering this monitor can be make slow or not
Message 6 of 14
Beyondforce
So, even though you disable the "Display scaling on high DPI settings" for these two files, FusionLauncher.exe and Fusion360.exe, your Fusion is still slow?
Ben Korez
| YouTube
Message 7 of 14
TUKTAK3D
Yes still have slow and same situation.
Message 8 of 14
Beyondforce
Interesting, maybe @James.Youmatz will be able to help.
Ben Korez
| YouTube
Message 9 of 14
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Beyondforce and @TUKTAK3D,
Thanks for the tag! I think I can help you out. @TUKTAK3D do you mind creating a screencast (link to download here) of what is happening? I guess I understand, but as @Beyondforce, that is very strange and I would like to see it firsthand.
Can you also open your Graphics Diagnostic dialog from the Help menu. I am curious to see what that dialog is reporting.
Edit: Whoops, thanks @Beyondforce Smiley Wink
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 10 of 14
Beyondforce
@James.Youmatz, check out the attachment in post 3!
Ben Korez
| YouTube
Message 11 of 14
TUKTAK3D
Hello thanks for the support.
Here is 3:50 am so I am in the bed...lol
I will leave the comment tomorrow as you requested
Thank you very much 😄
Message 12 of 14
James.Youmatz
Autodesk Support
Autodesk Support
Hi @TUKTAK3D,
Is this issue still occurring today? If so, can you please create a screencast so I can try to see what is happening with the mouse cursor.
James Youmatz
Message 13 of 14
TUKTAK3D
Hi  @James.Youmatz
Yes still having mouse cursor really slow when draw the line.
I attached video what happen. I can not handling the each step of drawing
Message 14 of 14
jeff_strater
Hi @TUKTAK3D,
Jumping in here:  I watched your video, and I don't see any slowdown.  What I do see, that might be confused for slowdown is that sketch grid snapping is on.  When this option is enabled, each sketch point will only snap to a grid point.  So, as you move the cursor, the point will stick to a grid point until it "jumps" to the next grid point.  You can turn this behavior off if you want more "smooth" sketching, but it doesn't look to me like you have any inherent slow behavior on your computer.
Here is a screencast showing how to disable grid snapping:
Jeff
Jeff Strater
Engineering Director
