sketch - issues with popups and no automatic constraints...
is there some way to switch off this popup, or atleast delay it? so far as i can tell this only started after the last update, and its infuriating as it seems to pop up after only half a second or so, often getting in the way of normal work (it also follows the curser unless i move it well away from the objects in question, which is doubly annoying).
Secondly, is there a way to have lines or other sketch elements (like a center to center slot) automatically create constraints like 'coincident' if they're created 'attached' to a different sketch element, like a line? I quite often need to put in half a dozen or more lines etc and its time consuming to have to add each coincident constraint one by one after having created all the lines... hoping there's a setting somewhere i cant find.
thanks!
