@schneik-adsk wrote:
@yoshimitsuspeed
Getting data from users is the first line of attack for all Autodesk applications when trying to reproduce and fix customer issues. The AutoCAD team will ask and the Inventor team will ask. Data and steps to reproduce is the fastest way to help the software team understand the problem and fix it. I can personally attest to companies working on DOD, aerospace and other projects that are happy to share data (often under NDA) with us. Please don't go off and make tangential insults when we only are trying to help.
I have tried to replicate your problem for an hour now and can not.
I understand you are frustrated and you want this fixed. Help us do that. You can always email us and we can handle this case off the forum in a way that meets your concern for privacy. If that means an NDA we can do that too. Brian will reach out in email so we can work on this is a way that address your security concern.
The first video is trying to get the sketch fully constrained. Once it is as yours is then it will often behave normally within certian parameters but very often if you try to make a big change, say taking a dimension from 10 to 50 it will still often flip out and reverse tangencies or flip an arc all the way around. I finally got that section fully constrained by finding the exact order to add constraints in but just that one added probably 30 min to the project. In all I probably lost over an hour to constraint, flipping tangets and similar issues yesterday.
The constraint error is sporatic and I think has mostly to do with the solver.
The biggest problem is that it can be overconstrained and still let you do some things and not others. The worst part is that it doesn't tell you where the constraint conflict is so you need to just start deleting your sketch or constraints till it starts to work again. Then some times it won't be over constrained but it will be 100% convinced it is. I have had this happen on such simple sketches that I could be 100% sure it wasn't overconstrained. Or like in that second video where when I try to move it by hand and it allows free movement but when I try to dimension it all of a sudden it's over constrained.
If the sketch is overconstrained then the conflicting constraints shoudl be highlited or something. If the solver can't find the conflicting constraints then it should not throw an over constrained error.
There are other times that
https://www.facebook.com/groups/1229995573786339/
