Sketch edit crash with consistent repro
etfrench
Mentor Mentor
etfrench
Trim operation in this sketch is crashing Fusion 360.  Other operations also cause crashes.
The main question is whether or not I can continue to use the original source file of the sketch without having to worry about the corruption affecting the model?
The offending file is attached.
p.s.
CER_140837502
CER_140837295
ETFrench
jeff_strater
@etfrench,
yes, that is reproducible.  Thank you for sharing the design.  We will look at this and see what the root cause is.  I'll see whether the design can be salvaged.  My guess is that it is fine, that this is just a Trim bug, but I'll poke around a bit and see what I find.
Jeff
Jeff Strater
Engineering Director
jeff_strater
I found the problem child in this sketch - somehow the pattern constraint has gotten corrupted.  If you delete that constraint, trim and the few sketch operations that I tried seemed to work OK.
If you have an earlier version of this design, before it went bad, and if you have any idea what operations you were doing when this started happening - was it all Trim? That will help us find the root cause of the problem.
Here is a screencast showing how to salvage the design:
Jeff
Jeff Strater
etfrench
There were several other crash reports for this, but I didn't save the IDs.  There were a few deletes as well as trims prior to the crashes.
The sketch is part of a much larger assembly so I wanted to be sure that wouldn't be affected by this corruption.  This sketch is pretty simple and I didn't have any trouble redoing it.
I can give you permission to the file if you need it for your investigations.   I'm not sure which version was the last before the crashes. It's at v21 now.
ETFrench
