sketch: deleting repeated items?
is there a simple way to select and delete the repeated features in a sketch pattern?
- deleting the pattern constraint leaves the repeated elements behind.
- i can't enter '1' in the 'Quantity' box of the constraint edit panel.
- there doesn't seem to be any way to select all the elements in the pattern.
i guess a workaround is to change the pattern quantity to '2' and then delete the pattern constraint, then manually select and delete the other element. that works, and maybe i'm missing something obvious, but it seems like there could be a whole slew of feature that could make this easier:
- right-click menu on the constraint (or any of the items in the pattern) to select all the items in a pattern.
- right-click menu on the constraint (or any of the items in the pattern) to delete the constraint ALONG WITH the repeated elements.
- allow '1' in the pattern quantity box
