- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For the past couple of weeks I've noticed Fusion acting weird. When drawing a sketch my geometry won't let me apply constraints to them (The geometry is not over-constrained). I will use the dimension tool then I will be able to select one of my lines but on the other. The same happens for the other constraints as well. I also will eventually add a constraint, but then when I apply another constraint the first one will disappear. In the attached screenshots I drew a 2 point rectangle that was constrained at one corner. I then applied a coincident constraint to the other corner and the horizontal verticle constraints disappeared creating a "not rectangle'. If anyone knows whats going on please help.
