Sketch constraint is broken
Message 1 of 9
I encountered a trouble of sketch.
Please look at the following Youtube.
http://youtu.be/aJ1hkaUanY0
Is there a workaround?
KG.
Replies (8)
Message 2 of 9
promm
Aaa_sekkei,
After reviewing your video I tried to reproduce and I am getting different results.  Please try two different workflows for me and let me know if you still have the same results.
1. Constrain the circle to the center of the origin, then add the radius dimension to the Arc.
2.  Instead of drawing the Arc past the circle then trimming, start on the circle for your first point.  If a tangent constraint is needed add after the Arc is created.
Cheers,
Mike Prom
Message 3 of 9
Hi Mike,
Thank you for your reply.
Your figure is seems to center of the two arcs do not match.(It is a groove for guiding the pin)
I need that the two center are the same position.
When the arc center is matched, constraint is broken by parameter change again.
For this reason, I think that without a fragile sketch, use a Boolean cut by robust model.
I hope that the sketch is robust.
Thank you.
KG.
Message 4 of 9
My colleagues have created in Inevntor.
That can be perfectly controlled by parameters.
KG.
Message 5 of 9
schneik-adsk
Here is one approach that works while we look at the error.  I used a construction line to control the distance using a linear aligned dimension.
Kevin Schneider
Message 6 of 9
sanjay_jayabal
Here is what I did. If this reflects what you are trying to do, I am happy to post my Fusion file.
1. Create a circle.
2. Create 3-point Arc starting from a point on the circle.
3. Create a tangent constraint between the arc and the circle.
4. Create a center-point arc as you did in your video (same center as the first arc and starting point of the arc from the center of the circle).
5. Add the dimension to both arcs.
6. Modifying their dimensions, properly resized the circle.  (Note: I did notice that changing the dimension of the outer arc updated the circle size only every other time.  That is, the size didn't refresh on the screen visually until the dim was changed again.  However, my geometric constraints were maintained and didn't break)
best regards,
Sanjay Jayabal.
Message 7 of 9
sanjay_jayabal
One other thing I did to workaround the visual refresh problem (that makes it look like the constraint is broken) is to trim the circle to a semi-circle.  Hope this helps.
Best regards,
Sanjay Jayabal.
Message 8 of 9
Hi Kevin,
Thank you for your good idea.
I seems
Thank you.
KG.
Message 9 of 9
Hi Sanjay,
I can draw a good sketch by using some of the ideas.
Thank you.
KG.
