sketch bug - dimension not changing sketch
cekuhnen
Mentor Mentor
Message 1 of 8
cekuhnen
changing 2 to 1 mm does not change the sketch!
Screen Shot 2016-07-09 at 4.54.20 PM.pngScreen Shot 2016-07-09 at 4.54.24 PM.png
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (7)
Message 2 of 8
Bug workaround
Try to delete coincident constraint it still Seems like it gets stock some times...  after you have change the value you can add it again
Message 3 of 8
masa.minohara
Hi @cekuhnen,
I am sorry to hear that you are experiencing the issue! I have reported the issue to the development team for further investigation. (FUS-25966) To work around this issue, I deleted the dimension and added a new dimension, and it seems to work fine.
Thank you for reporting the issue!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 4 of 8
cekuhnen
@masa.minohara No worries.
Claas Kuhnen
Message 5 of 8
@masa.minohara  i maybe think it's the same bug - missing tracks of the parametric hierarchy. just a thought
http://forums.autodesk.com/t5/design-validate-document/fusion-make-som-wrong-over-constraints-over-m...
Message 6 of 8
TrippyLighting
I've experienced this as well. The sketch engine is very finicky in the way constraints are applied. It can certainly do wit a lot more robustness.
Message 7 of 8
masa.minohara
Hi @Anonymous,
Thank you for your response. The development is still working on the issue and I haven't received an update on it. I will make a comment here as soon as I have an update.
Masanobu Minohara
Message 8 of 8
skylord73
Hi All,I'have another issue with sketches and measure...
http://a360.co/2iPlEpM
Version 10 is the last correct one.
In Version 11 I changed one of the Parameters of the models (NrOfTeeth) form 11 to 45 and that created a big mess.
When I started revising the drawing to find out the problem, I stated that the Sketch8 (with some minor problems) gets the new measure, but that sketch14 do not scale up.
If you open the sketch you discover the problem is that the dimensions, correctly refer to the parameters, but where not updated when the parameter was changed
Edit: I created a new post... no idea on how to remove this one.
