01:47 AM
- Mute
- Permalink
- Report
Hi Folks,
I am trying to draw a bench from which the feet are 15° inwards. This has been my progress so far
- From top view, create sketch 1 and draw centre rectangle (400 by 900mm)
- From this centre rectangle, extrude a body or component (named "seating area") upwards with offset 400mm (seating heigth), thickness 18mm (thickness of the wood I'm using for the seating surface)
- From sketch 1, create offset rectangle which is 10% inwards (i.e 45mm left & right, 20mm front and back)
- From this offset rectangle and along the shorter 360mm line, create a construction plane that is 15° tilted towards he interior of the rectangle.
- On this construction plane, I am trying to draw a tilted rectangle starting from the bottom all the way to the lower side of the seating area.
And this is where i'm running into my problem : this tilted rectangle does not "auto-snap" or "auto-align" to the lower part of the seating area. Any tips on how I could solve this?
I added a video for a better explanation.
Thanks in advance for your support.
Best,
