Sketch auto hide?
Sketch auto hide?
KhaiE
Sketch auto hide?
KhaiE
  is there a reason all my sketches stay shown after i exit from editing? it sort of gets annoying having them all lit up everywhere....
-cheers
etfrench
I find it's more annoying that a sketch auto hides after I extrude an object from it Smiley Frustrated
ETFrench
masa.minohara
Hi @KhaiE,
Thank you for posting! Did you manually turn on sketch display by clicking the light bulb? If you have manually turned on, it stays shown until you manually turn off. Is this what you are asking?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
KhaiE
not quite....
im making multiple surface extrusions from a base body, when im done editing the sketch, i exit and execute extrude.....when im done with extrude, the sketch is still highlighted on the surface, and i see the purple relation lines, so i have to manually turn the sketch off after im done editing it?
masa.minohara
Thank you for your response! Would you be able to record a screencast of what you are seeing? I believe I'm doing something differently but I'm unable to reproduce it.
Masanobu Minohara
