Sketch: Angle of trimmed/breakes lines is given incorrectly
anna-luise.wokusch
anna-luise.wokusch
If I break up a line or trim it in the sketch, the measured angles are changed and contradictory, see screenshots below. I think this might be a bug?!
Fusion 1.pngFusion 2.pngAngle 3 seems contradictoryAngle 3 seems contradictoryAngle 1 that seems logicalAngle 1 that seems logicalAngle 2 that seems logicalAngle 2 that seems logical
Replies (9)
davebYYPCU
Fusion will be happier without you trimming the lines.
Leave them there and select multiple profiles.
Might help...
Marco.Takx
Hi @anna-luise.wokusch,
Can you share your model so we can take a look at it?
It's hard to say by only seeing those images.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
anna-luise.wokusch
Hi @Marco.Takx,
here you can find my sketch:
https://a360.co/2FB92lh
The line is still untrimmed in it.
Kind regards,
Anna-Luise wokusch
TrippyLighting
There is really little need to trim these lines, but if you really wanted to :
Marco.Takx
Very strange.
I'm more an Inventor user so I didn't saw this behavior before.
I've checked your model and I see the same behavior.
Actually, I did a test and came across this.
I projected an axis and made an angle between from 90 deg.
Also when I replace the angle dimension to a perpendicular constraint I see the same behavior.
Someone from Autodesk has to take a look at it closer at this.
Marco Takx
TrippyLighting
Watch my screencast. That'll reveal the "secret" 😉
Marco.Takx
Hi @TrippyLighting,
For the trimming that's all clear by me Smiley Wink.
What I found is that the Inspect is not working correctly in my opinion.
And that is what @anna-luise.wokusch also pointed out in the question.
Do you have that same issue after projecting a line and draw a line on the projected line 90 deg up.
The inspect in not 90 deg??
Marco Takx
TrippyLighting
No I don't in this case, but I have seen some similar cases before.
A screencast that shows how you reproduced this would probably be very helpful.
Marco.Takx
Hi Peter( @TrippyLighting),
See my screencast.
Marco Takx
