Simulation Question
Simulation Question
Simulation Question
hi
i did lots of simulation for my shaft with bearing but unfortunately all simulation have been failed ,and i get 14000 $ loss .
will you have any idea or help for my shaft simulation or can you please define me how i do perfect simulation for perfect shaft
actually i need to know how many factors and loads or all the related things require for getting successful simulation result if there is any video tutorial or guide line then please share that with me .
TMC.Engineering
I would recommend that you think about what you need to simulate.  Are you interested in the stress on the shaft? maybe just use a sizing chart for the bearings.  you should also post and example of what you have tried to do so far.  uploading the file would be a good start.  also making a short video with screencast is helpful.
Timm
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
