Simulation of hydraulic press plates
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day all,
I am stuck with an issue which I'm not quite sure how to solve with the Simulation functionality.
I have a hydraulic press where I am pressing 2 extremely thin materials in-between two Aluminium plates to fuse them. This process needs to be up-scaled. I would need to determine the plate thickness I would need to have the least possible displacement (in other words, I need to determine the plate thickness to have the most uniform pressure applied across the entire plate section). The plates outer dimensions are 430x340mm, inner hole (hole is for the press piston to reside) 3mm deep with 53mm diameter. I have used 10, 15 and 20mm thickness but can't seem to get my settings in order on the Simulation Workspace.
What I have tried:
1. A Static Stress Study with the following: A load with a force of 29 500N applied in the middle of the plate where the hydraulic press would be applying pressure and the constraint as the bottom of the plate.
2. A Static Stress Study with the following: A load with a pressure of 13.5MPa applied in the middle of the plate as well as at the bottom of the plate with the constraints as the outer 4 faces on the plate.
3. A variety of the above mentioned with different faces selected as constraints etc.
All results seem unreasonable and the thicker the plate the more displacement I get in the middle without any idea of what effect it has towards the outer edges of the plate as curling/bowing is bound to happen.
Any help is welcomed! Thank you in advance.
Tyler Henderson
