Drew up a bridge for school and went to sim it, but received this error code. Any help would be appreciated.
Error: FATAL ERROR T2225: SET LIMIT EXCEEDED
Error: Solver Error
Error: An error occurred while solving the model.
This error indicates you have more than 1000 surface/surface contacts. We will be implementing a fix in the next update which will raise this limit. Meanwhile, you can either simplify your model to reduce the number of total parts/contacts, or you could also boolean/join some components where you have bonded contacts and that should allow you to get similar results without so many contacts.
Sorry for the inconvenience.
Hi rileymariol,
As Rob pointed out, this is something we are working to address in a future release. In the meantime, would you be willing to share you model with us so we can see what you are trying to accomplish? I am interested to see what you are doing that has generated this large number of contact pairs.
Mike Smell
Product Manager, Fusion 360 Simulation
Attached are rendered PNGs of the model I was attempting to simulate. Thanks for the responses guys! I also have am Isometric view of it on my instagram @inhumanfabrication
Hi rileymariol,
Thanks for sending the model. This definitely helps with context and also makes it easier for me to give some guidance to get things to work.
I would ask yourself the following questions.
By just doing step 1, I was able to run a modal frequencies analysis with an assumed material and basic boundary conditions.
I will let you make the final decision on if this approach is applicable to your simulation requirements.
Please let us know if you have any further questions.
