Simulation Deformation Scale in Compare mode (static stress analysis)
kukajol
kukajol
Hi Guys!
Is there any way to change the deformation scale while comparing the results from Static Stress Studies?
It seems to be fixed to "Adjusted" scale, no matter what scale I had selected while switching to compare mode.
Does that qualify for a Bug submission?
bensbenz
Here in 2023, it appears this is still not possible... There is no button to set deformation scale once you go to compare.
brady_butlerLZNLU
Community Visitor
Community Visitor
Still an issue in 2025? 😞
henderh
Hi All,
Although it is still not possible in the May 2025 production release of Fusion, Deformation Scale adjustment display in Compare is now available via our web-based Results viewer.
This is live in our Fusion Insider program as a Preview Feature:
Thank you for bringing this to our attention, and please let us know if you have any additional questions, comments or suggestions.
Best regards,
ps: We're also working on adding Probe functionality to the Compare workspace in the Preview Features results viewer, which is also not available in the current production results viewer (tracking ticket FUS-96041). I've added reference to this topic thread, to help raise awareness of enhancement requests regarding our post processing inspection tools.
Hugh Henderson
QA Engineer (Fusion Simulation)
jay_tedeschi
Can someone please explain, or at least try to, why the default deformation display when using compare is set to "Adjusted RidiculousX"?
Seriously... if it is simply not practical from a development cost standpoint to add the functionality to allow for selectable deformation display when utilizing Compare, then at a MINIMUM the default should be set to Actual. I'll not bother with a screen shot as... A)  It looks ridiculous, and B) I'm pretty sure everyone who pays this thread a visit knows what we are referring to.
