Simulation cloud basis
Harshal_Belan
Harshal_Belan
In simulation add new material in fusion library as per datasheets of material. To apply the new material on product for simulation its required time to simulation and fails sometimes. Is it any reason behind that? Its happens just because new material add in fusion library !
lucasliraAU
Hello! @Harshal_Belan
You may need to post the file you are working on and also specify the type of simulation you are working on in your 3D model.
Post here so the experts can help in your case.
Greetings!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
