Simulation - Bolt Connector with a Preload
Roelof.Feijen
Advisor Advisor
Roelof.Feijen
In the Static Stress Analysis you can use a Bolt Connector with a Preload.
The Preload is applied before the part deforms, as the part deforms I assume that the Preload is reduced. Or is it automatically adjusted?
Is there a way to verify the Preload in a Bolt Connector? I can't find a way to display the line element force results.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Mike.Grau
Hi @Roelof.Feijen,
Thank you for asking about.
I have shared your post with our Simulation Team and they will reply as soon as possible.
It would be great if you could share a couple screenshots of your design and a bit more information
what you would like to achieve to see in this load case?
Roelof.Feijen
Hello @Mike.Grau,
If you want to know more, just read my article: Using Bolted Connections with Preload in FEA (Nastran In-CAD).
This question is about step 4.
Roelof Feijen
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Roelof.Feijen,
Thank you for posting!
Fusion 360 simulation has been improving considerably and I don't think we have enough post process yet. hopefully we will be supporting that soon.  Smiley Sad
If you need more help, please let me know. I will be glad to support you
Many thanks.
