- Mute
- Permalink
- Report
Is there an option to apply a constraint (e.g. frictionless or fixed) to a part of a surface?
Asume a beam with a flat bottom surface. The beam is supported on both ends. If aply a constranit I can only select the whole bottom surface, not just the ends. ( in my case the beam is about 1,5 m long and will be supported over the first and last 4 cm's)
a workaround would be to create a small surface at the ends and extrude it just a little bit, but i am afreight that will cause problems in the mesh. another workaround would be to make an assembly for the simulation.
But ideally I would just choose to apply the constraint to the ends, maybe just creat a sketch and be able to select that skecth as the surface to aply the constraint to.
